Thread: How do you fill your Liquidator?
    Sep 2007
    I would be interested to hear how everyone is filling their Liquidator.
    Do you just add chlorine and let the water overflow the top?
    Siphon off some water?
    Durleigh built a stand and he places a 5 gallon jug on top and siphons it in.
    I was thinking about drilling a hole near the bottom and installing a valve for quick emptying. What do you think?
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
    revstriker's Avatar
    Apr 2008
    Re: How do you fill your Liquidator?
    When I filled mine, I used a bungee cord to hold up the float on the inlet side and poured in the chlorine really slow, at about the speed of the outlet valve. Never came close to overflowing.
    10K White Plaster Pool Built in 2007. Hayward Pump and DE Filter, Hayward Navigator, Liquidator (Removed due to issues), Solar Blanket, BBB user.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    I've refilled while the pump is running and never had an overflow.
    It seems that the "white stuff" is unrelated to how you pour in the bleach, provided that you do it through the funnel, and not TOO fast.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Nov 2007
    Austin, TX
    I installed a valve on the inlet side of the LQ. I fill with the pump running and the inlet valve closed and can pour in the bleach w/o any problem.
    My Pool
    15k Gal Gunite Pool w/8 ft Spa w/Spillover
    Hayward DE Filter + DE Separation Tank
    Legend Sweep, Pentair Gas Heater
    Stenner Metering Pump for Liquid Chlorine Injection (15 gallon tank)
    Mar 2008
    Garden State
    So far I have been manually holding up the float on the inlet side, leaving the pump running so liquid is flowing out as I pour bleach in. Added a full 8gal this way the other day. I plan to add a flow control valve on the inlet side so I can just shut it off as opposed to holding the float.
    Pool Details:
    - inground vinyl liner, approx 35,000 gal; Hayward DE-6000; Pentair VS3050
    - 600sq ft Heliocol; Blue Diamond; 8 Gal Liquidator
    - TF-100
