Results 1 to 12 of 12
Thread: New Pool CYA at 90... Do I drain or wait?
    Sep 2013
    Orange, TX
    25
    Pool is over a month old and I have adopted the BBB method and turned off the chlorinator.
    Test results from today with Taylor k-2006 kit
    FC 3.2
    CC .2
    TA 90
    ph 7.6
    Hardness 280
    CA- 90
    Borates 34
    I added bleach to raise the FC to 7 this evening. With this late in the season should I drain to get CYA down or just keep the FC at proper levels and see if CYA comes down with use and rain?
    18,500 gunite/pebble plaster, Taylor K-2006 test kit, Jandy 2hp variable pump, cart. filter, ozone system, in-line-chlorinator(not in use), borates, Polaris 9400
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Pool CYA at 90... Do I drain or wait?
    I would say if you water is clear, wait to drain and just make sure you FC never ever drops below 7 ppm and you should be fine. That will require you to shoot for a higher FC when you dose. I would try shooting for 9-10 ppm FC.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    How long till you close or if at all ? You could drain some to get it down if your going to be using it alot. It's your call.
    Your FC level at 7 ppm is at the min for a CYA of 90. Your FC should be at least 10 ppm so you don't fall below your min of 7 ppm.
    Jeff
    Sep 2013
    Orange, TX
    25
    Yes, water is clear. Since I live in Texas, we will use it thru Oct. I planned on keeping it up all year unless there is a better way. I will keep FC between 9-10. Should I increase Borates to 50?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What is your current borate level?
    I probably would wait until after you do a drain/refill to reduce cya.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Just one more thing.... Stay on top of your FC levels cause if you get an algae bloom its gonna take a boatload of bleach to clear at a CYA of 90.
    Jeff
    Sep 2013
    Orange, TX
    25
    linen.. borate is at 34
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would leave it until you drain so you don't waste your chems.
    Sep 2013
    Orange, TX
    25
    Ok, I plan to leave it and drain later.
    Quote Originally Posted by kdiamond
    If there are tabs in the chlorinator, I would recommend allowing them to be used up or remove them. Turning off the chlorinator only isolates the tabs in the feeder with water. They continue to dissolve, creating a very concentrated chlorine solution that can damage the chlorinator and can be dangerous when the chlorinator is opened.
    Support the site
    Sep 2013
    Orange, TX
    25
    Thanks James. I did not think about that.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Wait to drain, keep up your chlorine level above 7ppm. Pucks will do that. LOL
