Thread: Wind getting under winter cover
    May 2013
    Ottawa, On, Canada
    32
    Hello,
    Last year i had TONS of problems with my winter cover on my 27' above ground pool. Before the water froze, and after it thawed every time wind blew (even just a little) air would go up underneath the cover and inflate it like a giant balloon 10' in the air. I called the store I got the cover from and their only suggestion was to add more water on top of the cover, but it didn't seem to do anything as the water would just get pushed to the far end of the pool and it would inflate again.
    Does anyone have any suggestions of something I can try before I close the pool down for the year?
    David
    27' AG Round (~17000 Gallons or 64000 L)
    Hayward 1.5 HP Power Flo Matrix Pump (2 speed usually run 6hrs high 18hrs low)
    Hayward CC150CAN XStream Cartridge Filter (150 ft^2 120 GPM)
    Hayward AquaTrol SWG
    Installed April 2012
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Wind getting under winter cover
    You could try winter cover clips or the plastic wrap.
    Jeff
    massimo's Avatar
    Jun 2013
    Manahawkin, NJ
    40
    Welcome to TFP! I would try Winter Cover Seal Wrap. Check it out. Seal Wrap Its pretty cheap too. Good luck
    Massimo
    15X30 AG Vinyl (10,600 GAL) Hayward Power-Flo LX 1.5hp
    Hayward Sand Filter, Pool Rover JR, 12ML Solar Cover,
    TF100, BBB Method! POOL SCHOOL
    I Don't Get "Pool Stored!"
    Smykowski's Avatar
    Sep 2011
    3,065
    I had good luck with a little strategic positioning of the winter cover. In the Chicago area, the prevailing winter winds are mainly out of the south, and I was having the same problem with the southwest corner of my pool. What I ended up doing was positioning the grommets on the south and southwest side of the pool exactly between the pool legs. This way, when I cinched the wire down tight, the wire pinned the cover against the legs while the wire in the grommets held the cover down between the legs. On the north and northeast side of the pool, the lineup didn't matter as much because the wind wasn't as much of an issue on that side.
    Does that make sense?
