Results 1 to 17 of 17
Thread: Wanda Works good but cloudy water
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    So I am on my first full season with the pool
    The last several months my pool gets brown streaks on the floor???
    I have a wanda the whale, and she cleans it up great in like 3 hours.
    also the water will get a little cloudy when she is done.
    2 days later the pool is sparkling clean again but the brown streaks start to show up again?
    So tonight I backwashed the filter till clean and rinsed for like a minute , thinking that may be the cloudy issue.
    But she is running for about 1 hour and its starting to get cloudy again?
    We put the pool in late last year (Late july)
    I dont remember getting theses brown streaks like I am now, Pollen has been high this summer.
    Could that be it?
    Or do I have a filter issue???
    I run the filter 12 Hours everyday The pool will become sparkling after a while but the brown dirt type streaks are annoying
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Wanda Works good but cloudy water
    I could also be dead algae or sand on the floor. The clouding could be due to algae or it might be calcium clouding. Post a full set of test results (FC,CC,ph, TA, CH, cya).
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Wanda stirs up some of the fine dirt on the floor of the pool. Some of the débris is fine algae. I would venture to guess your chlorine is just barely keeping up with your algae.
    A full test result will help us help you.
    -- Guy --
    Makdaddy's Avatar
    Jul 2012
    119
    OK
    Ill get chem levels on Thursday nite after work if its not raining
    --- Greg----
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by linen
    OK FC 1.12
    Alkality 90
    Total CL 1.57
    Cyanuric Acid 35
    Salt 3330
    Ph 7.8
    Looks like it may be some type of algae
    Im going to Shock it after I vacuum and see what happens this week.
    Im looking at it good after wanda goes over it and looks liker it leaving a little stain on the liner..
    I have the pool shocked to 22.5
    Ill turn off the SWG and test at sunset and again in the morning to see what happens
    --- Greg----
    Makdaddy's Avatar
    Jul 2012
    119
    So CL dropped to 19.5 from 22.5 overnite
    I will bring shock level back up to 22 or so and retest tonight..
    My CYA is at 35 its way low
    Should I just keep slamming around FC 21 PPM or should I bring the CYA back up?
    Or lower the FC Shock level to 16 per the chart?
    Funny my water was always nice and clear all summer.
    it only got cloudy when I vacuumed and then would clear right up
    --- Greg----
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Since you failed the OCLT, keep SLAMing and don't bring your cya up until you complete the SLAM process.
    Makdaddy's Avatar
    Jul 2012
    119
    Will do
    I just checked it
    Its at 18 what level should I try to shock at?
    With my CYA at 35 should I target 14 like the chart says
    tested this morning FC down to 14 but CC is at zero
    I added a little 12.5% Bleach (64 oz) and will test again tonight when I get home
    --- Greg----
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Keep your pool at your SLAM level of 14 ppm (if you go a little higher when you can be at the pool to dose, that is generally okay) until you finish the process.
    Makdaddy's Avatar
    Jul 2012
    119
    Slam seemed to have worked out
    I brought my Fc up to 18.5 last eve and shut down my SWG
    I tested this morning and was at 18
    Water looks good and clear
    CC was Zero
    I will scrubb pool down and backwash filter tonight.
    I will be wintering soon. Should I bring the CYA back up ?
    Thanks Guys
    --- Greg----
    38,290
    Have you passed all 3 criteria to stop the SLAM process? ... Looks like you have assuming there is not visible algae and the water has cleared up.
    Why do you think your CYA at 35ppm is too low? That is within range and you are a good bit north so the sun is less intense .... OH, duh, you mention a SWG but it is not listed in your signature. Sounds like you can bring the CYA up for the SWG ... unless you are about to close in which case I might just wait until the spring.
    Makdaddy's Avatar
    Jul 2012
    119
    Fixed my SIG
    Ill hold off on the CYA till next year
    I will just winterize like I did last year and hope for the best
    --- Greg----
    38,290
    Have you seen the closing articles in Pool School? Just to verify your process.
    Makdaddy's Avatar
    Jul 2012
    119
    Yes I shopuld be good to go
    --- Greg----
    Makdaddy's Avatar
    Jul 2012
    119
    Well
    I left my SWG off by accident for a day
    FC got down to 3
    Algea came back but very small amount
    I have shocked it back to 19
    Will start all over and see what happens my CL is still zero
    --- Greg----
    38,290
    I assume you mean your CC is 0?
    Makdaddy's Avatar
    Jul 2012
    119
    Yes My bad The CC is at Zero
    I have several small streaks of brown back on the floor
    --- Greg----
