Thread: Can't get old drain cover off...
    I'm trying to replace my old drain cover with an SDX Retro. But I can't get the old one off. There's no screws in the screwholes, and I've tried to twist it off, but no luck. Do you think it's glued in place? Anyone familiar with this type of cover?
    [attachment=0:3vj6pj4i]IMG_0022.jpg[/attachment:3vj6pj4i]
    Worse comes to worse, I'll get a hammer and chisel. (Yes, I'm renting scuba gear -- just need to find my PADI card...)
    25,000 gallon IG plaster pool (c.1963). Pentair Intelliflo VS. Clean n Clear Plus 320. Pentair East Touch 4P. Intellichem with liquid chlorine dispenser. 8 Aquasol 4x10 Panels. Polaris 280 w/booster pump.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Can't get old drain cover off...
    That particular drain cover needs to rotate 1/4 turn counter clock wise to remove. They are very tight and your thought about a hammer and chisel is the correct answer. The new cover will not fit the same way it will have to be screwed down with stainless steel screws
    Thanks for the tip -- much appreciated! I gave it a go today, but couldn't budge it. Looks like I'll need some scuba gear to get this done.
