Thread: Inground Spa seems to lose water...
    Split from inground-spa-seems-to-lose-water-t40440.html Butterfly
    I seem to have the same problem. I changed my jandy check valve, and the water in the jaccuzi is still draining after the pool stops running. I'm a first time pool owner and I'm not sure if I'm setting the valves correctly.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Inground Spa seems to lose water...
    Welcome to TFP!
    I know this is an older post and no one answered it, but wanted to encourage you to continue to post and ask questions. Not every question gets an answer, but we should have at least welcomed you to the forum.
