Thread: I have a leak
    Sep 2013
    Tennessee
    1
    I have a leak
    Split from tip-for-finding-a-vinyl-liner-leak-t69420.html Butterfly
    New member - often browsed these forums for help with my pool. I haven't updated my profile / signature yet - pool info below.
    My leak fits the symptoms in this post. I have a leak and suspected it to be around the lights (I have had one there before), skimmer, or return lines. I cannot find leak using food coloring test. However, I do have a slight "ballooned out" liner on one side of the pool. I cannot see any tears around this area. Is it possible there is a leak nearby - perhaps along the floor - that causes it to balloon out on the side?
    30,000 gallon "L" shaped in-ground pool. Vermiculite with vinyl liner. Salt system, sand filter, hayward 1.0 pump.
    Thanks for any advice.
    P.S. I found my first leak around my light using a hydrophone. May have to find that and try that again.
    30,000 gallon pool - Salt system - IG - Vinyl - Sand Filter - Hayward 1.0 pump
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: I have a leak
    Welcome to TFP!
    I know this is an older post and no one answered it, but wanted to encourage you to continue to post and ask questions. Not every question gets an answer, but we should have at least welcomed you to the forum.
