Thread: non-removable ladder?
    I have a ladder that is rusting and I have read how to clean it when it is removed. However, I do not see any anchors or bolts holding the ladder in. I lift up the plastic caps and see only concrete. Is it possible that the builder neglected to use any type of anchors? Is so, is there no possibility of ever removing it?
    27K Vinyl IG Pool
    18x36, Aquarite with Goldline T-15 SWG,
    Hayward 244T Sand Filter, 1.5 HP Hayward Super Pump w/ AO Smith B129 Motor
    Taylor 2006 Test Kit
    NW Louisiana
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: non-removable ladder?
    Often the concrete gets worked over the anchors. You should have bolt heads very close to that side of the rails. Maybe tap at the concrete lighly to see if the are under the surface.
    This is the most common type used around here
    You back the bolt out and a wedge drops which releases the ladder.
    So the idea of the builder not using anchors is very unlikely? I also have a diving board that utilizes 2 U shaped rails (no plastic caps); are they typically anchored as well?
    Thanks for the quick reply (I would not have thought they would work the concrete over the anchors).
    27K Vinyl IG Pool
    NW Louisiana
    cautiously, I did tap around the ladder and found a bolt head. I feel much relieved now that I know it's there.
    Thanks
    27K Vinyl IG Pool
    NW Louisiana
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Around here, a sleeve is required to be bonded (wired, like grounding but not), and bonding inspected prior to the concrete pour. Not sure if/how electrical inspection could pass without having the "cups".
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    SW Indiana
    9,198
    Quote Originally Posted by SilverJK
    Thanks
    Good deal.
    They pull a wedge up to secure the rail, so you want to loosen the bolt a little (1/4 inch), then tap on it to push the wedge down. Repeat until you can feel the rail loosening. If you take the bolt out, the wedge usually stays in position and the rail won't move.
