Thread: Is this right?
    Aug 2013
    League City, TX
    31
    Is this right?
    My pool is exposed to the sun from around noon til sundown. I am trying to keep my FC at 8. My CYA is 70. I am having to add @ 40 oz of 8.5% bleach. Is this right?
    My last readings were:
    FC 4.5
    CC 0
    CYA 70
    TA 100
    pH 7.8
    CH 300
    Per the pool calculator, I need to add 87 oz of bleach. I can and will do that but seems excessive. That being said, my pool looks AMAZING after switching to the BBB method.
    18K / in ground / PebbleSheen /Hayward pump / DE filter /spa / Polaris cleaner
    Built July 2012
    Feb 2008
    Denton, TX
    5,061
    Re: Is this right?
    If you are wanting to get your FC up to 8 ppm, that seems about right.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Is this right?
    A typical pool at 70 ppm will lose about ~25% FC due to the sun. 5 ppm is the lowest you want to allow your FC to go to, so if you target 6 ppm as a minimum, that would mean your pool should use about 2 ppm/day with a target level to dose to of 8 ppm. If you are dropping from 8 ppm to 4.5 ppm daily without a lot of swimmers, then I would guess you have something in the water using up your chlorine. When in doubt, do a OCLT: http://www.troublefreepool.com/pool-...rnight_fc_test I would bring your FC level up to at least 8 ppm before taking your evening reading.
