Well I had a horrible day at work only to come home to a non functioning main pump. While taking off the cover to check the power to the pump the bold sheared off. While turning the power back on to check with my meter the pump started working again. I then found out that the power had flickered during the day which probably caused the automation to get confused. Anyways how can I get the cover on the pump tight again?
