Thread: Ortega Flo-Chk rattles
    I have a noisy check valve. The spring costs about $12 and the seat assembly is about $50. Which should I replace to quiet the noise? Thanks.
    24000 gallon in-ground | 500 gallon spill-over spa | SWCG T-15 cell | PS-8 control panel | Solar panel heating | Propane heater | Jacuzzi TM 31 sand filter | Jacuzzi 2HP 240V pumps (one each for filter and spa jets) | Jacuzzi TM 31 sand filter | Auto-leveler |
    Aug 2011
    Southern California
    188
    Re: Ortega Flo-Chk rattles
    My Ortega was doing the same. I took some o-ring lube and lubed up the face and edges of the seat assembly rubber. No noise since.
    22,548
    Try lubing like Hawk suggested and if that doesn't work I'd change the spring.
    When I pulled the seat assembly, I found the rubber was badly out-of-round. Silicone lube didn't help. Next, I swapped parts from another valve and that didn't help either. Finally, I screwed the cap on with no guts and that made it quiet. So, I'll go with new innards and hope that works.
