Results 1 to 10 of 10
Thread: Sand coming out of hose during backwash?
    I am currently SLAM'ing my pool and have been backwashing once a day and started noticing yesterday that sand was coming out (I back wash into a big bucket I later dump out). I also have notcied what appears like sand in the bags of the robotic vacuum, but I am not as sure on this part as I know our roof will blow things into the pool during a good wind and it could be lose stuff from the shingles...
    Is sand coming out of the filter normal during heavy use (the filter is running fulltime now during SLAM). Should I wait until after SLAM'ing and look or is this a major issue I need to look into asap?
    Pool Info: 15,000 gallons, In Ground Pool
    30,413
    Re: Sand coming out of hose during backwash?
    How much sand?
    How much sand?
    The water being backwashed looks like the color of sand and in the bucket I backwash into there is at least an inch or two of settlement
    30,413
    Yeah, that's way too much and needs to be fixed. When did this start happening?
    It would have to be this week. I was out of town for 8/9 days and came back to a greenish pool and started SLAM'ing and then noticed during backwashing.
    Do I need to try and find a local repair person? I have no time to deal with fixing the pump myself and we have a big party this weekend with the pool and it needs to be back to normal...
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Check the spider gasket in the filter's multiport valve. If it is not seated correctly or deteriorated it can allow sand to escape the filter. Is the only time sand escapes is when you backwash?
    Love TFP? Become a
    TFP Supporter!
    Quote Originally Posted by zea3
    It might also be during normal filtering through the water return part, but I have not been able to conclusviely figure out if it is from the pump or the roof yet. If it also comes out from the return could that be from the spider gasket?
    Jul 2009
    Houston, Texas
    9,379
    Maybe. A few more questions. Is there a lot of sand in the pool? Do you shut the pump off when you change settings on the multiport vale? Do you set the filter on rinse until the water runs clear after back washing?
    One way to check if the filter is letting sand into the pool is to hold a clean sock over the return while the pump is running and see if you collect any sand in the sock.
    Love TFP? Become a
    TFP Supporter!
    Alot of sand -> not noticeable by looking at it, but the robotic vacuum seems to pick up a small amount
    Shut off pump when switching -> Yes
    Rinse -> Yes
    Nice idea on the sock! Was trying to think how I could test it!
    30,413
    Explain what you mean by settlement....is it sand or debris that your filter has collected?
