Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Green Swamp in new IG pool
    Jennica's Avatar
    May 2012
    NJ
    91
    Hi! My sister's brand new pool is a green swamp because the builder told her that someone would come and balance the water but they never did.
    I took a reading with my K2006:
    FC 0
    PH Off the charts high
    TA 150
    CH 225
    CYA 0
    It is an IG with vinyl liner. Don't know the gallons but it is 16 x 33 rectangular shaped and goes from 3 1/2 ft to 6 ft deep.
    Do we start with the SLAM process first or start by getting the PH down?
    Since there is no CYA in the pool is it ok to use the bags of shock? Or should we just go the Stabilizer/Bleach route?
    The water is thick and green. I'll post a pic later if I can cuz I know you guys love them.
    Thanks!
    15' Round Above Ground 5,300 gallons
    Cartridge filter
    Taylor 2006 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Get the PH down to 7.2. before starting the SLAM process.
    I like to use just stabilize for the CYA because I know for sure how much I'm adding. Shoot for 30 ppm for the SLAM process. Then bleach for chlorine. IMO. Others will say different.
    Jeff
    Jennica's Avatar
    May 2012
    NJ
    91
    Re: Green Swamp in new IG pool
    Ok, will do. Thanks!
    Cartridge filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your going to need to figure out the pool volume.
    Jeff
    38,301
    I would put the pool around 19k gallons.
    I would suggest:
    1. Get 30ppm of CYA in the water
    2. Adjust the pH down to around 7.2
    3. SLAM it
    Jennica's Avatar
    May 2012
    NJ
    91
    Yeah, the PC said 19K and change, was gonna round it up to 20K to be on the safe side.
    Thanks, guys! Will post results.
    Cartridge filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes keep us posted with pic's if possible !!
    Jeff
    Jennica's Avatar
    May 2012
    NJ
    91
    So we added the MA and will test PH in the morning.
    FC 12
    CC 1
    PH ?
    TA 150
    CH 225
    CYA 30
    In two hours the FC hasn't gone down at all. Is that normal?
    Cartridge filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you can test ph one hour after you added the MA and recalculate and redose. Repeat this until the ph is down to 7.2. It is likely her ph is still high.
    Generally we say ph is not valid when the FC is above 10 ppm, but if you are using the taylor ph test, it probably is okay testing at 12 ppm FC.
    Jennica's Avatar
    May 2012
    NJ
    91
    Thanks, Linen. Does the PH being high hinder the chlorine killing the algae?
    Cartridge filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Jennica
    If ph is really high (or really low) it can. But with cya in the water, chlorine effectiveness at higher ph (<9) is not a big factor. The main reason we suggest a lower starting ph is to protect against the effects of the temporary boost in ph that will occur while SLAMing due to high FC levels maintained. This temporary higher ph could have the potential to cause calcium scaling or cloudiness depending on the other water parameters. It can also cause metal staining if their is sufficient metal in the water.
    Jennica's Avatar
    May 2012
    NJ
    91
    Gotcha. Thanks again!
    Cartridge filter
    Jennica's Avatar
    May 2012
    NJ
    91
    Success! After 24 hours and just a few doses the PH is in range and the water is cloudy, but blue.
    She's going to keep up the SLAM process until she passes the OCLT. BBB strikes again!
    The pics are from last night and this morning. It's even clearer and bluer now.
    My sister thanks you!!!!
    Cartridge filter
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Very nice job !!
    Make sure she pass's all three tests before she stops.
    Jeff
    Jennica's Avatar
    May 2012
    NJ
    91
    Will do.
    Cartridge filter
    Jennica's Avatar
    May 2012
    NJ
    91
    She's getting to the end of the process and I think she will pass the OCLT tonight. The water is still pretty cloudy. I know that's dead algae but was wondering about how long that should take to clear? She has been running the filter non-stop.
    Cartridge filter
    38,301
    Keep at SLAM level until the water clears.
    What kind of filter?
    Jennica's Avatar
    May 2012
    NJ
    91
    Oh, ok. I know the criteria are less than 1 ppm FC loss and .5 CC or less, but I wasn't sure if clear water meant clear of green or clear as in not cloudy. Thanks!
    It's a cartridge filter.
    Cartridge filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Clear as in clear to the bottom, no-cloudy.
    With a cart filter, it most likely will need to be cleaned often. We recommend cleaning when the filter pressure goes up 25% from the clean filter pressure. What is the clean filter pressure?
  20. Back To Top    #20
    Jennica's Avatar
    May 2012
    NJ
    91
    I believe the clean pressure is 12. It also has an arrow that will point to "Clean or Dirty" as the pressure goes up. I will tell her to check the gauge.
    Cartridge filter
