Thread: TA still low
    Aug 2013
    St. Croix, USVI
    11
    TA still low
    Pool looks great. Water temp is high this time of yr in the VI's (86 deg).
    FC and TC fine 3.5ppm pH fine 7.6 but TA always seems to be low 50-70ppm. Have added TA+ but I'm hesitant to add more Baking soda for fear my pH will skyrocket. Any thoughts?
    Marbelite 13K gal pool in Rain Forest St. Croix USVI (opened 08/04/13)
    Hayward 2030 cartr filter (225sqft) Hayward skimmers
    Lorenz Solar powered pump 4 Ecogreen PV panels 245W ea w A/C back up Polaris 360 cleaner w separate filter
    Location is 17deg 47' N Water Temp 82-86deg Ambient temp 75-90deg Rain Fall 60-90"/yr Altitude 615Ft ASL Sun Solar Exposure 11:34 to 12:25hrs/day
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: TA still low
    Welcome to TFP!
    Quote Originally Posted by Chu1ck
    Baking soda has virtually no effect on pH.
    Total alkalinity indicates the water's ability to buffer pH changes. If your pH is relatively stable, I would leave TA where it is, but I wouldn't let it get below 50 though. If you do need to increase TA, go ahead and add the proper amount of baking soda and don't worry about any adverse impact on pH.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: TA still low
    Yep leave TA alone. The higher the TA gets the faster PH raises.
    Jeff
    38,295
    Re: TA still low
    How are you testing? The TA test in the recommended test kits does not result in a 50-70ppm range.
    BTW, please edit your signature to a max of 5 lines as stated in the Forum Rules for signatures. Thanks.
