Results 1 to 8 of 8
Thread: new Solar Heater - questions about Chlorine Usage and SWG
    Feb 2010
    South Florida
    73
    Hello. I just had solar panels installed. I have a 2-speed pump, and the solar controller is set up to switch the pump into high speed when solar heating is needed. When my pool was set up, the installers set it so that the salt water chlorinator only runs in low-speed mode. Their explanation as to why wasn't a great one, but at the time it didn't matter.
    Now that I have the chlorinator, it does, as the pool will be running more, and in winter a lot, in high-speed mode. The tech who installed the panels had many misconceptions about pool functioning, so I take what he said with a great degree of suspicion, but when I asked him about whether to have the chlorinator run in high-speed mode too, he said:
    • The amount of chlorine produced is similar in high and low speed modes, i.e. it is independent of the speed of the pump
      The hotter water will consume more chlorine.
    I read a post on here that JasonLion said that hotter water does use more chlorine. However it was my impression overall that UV consumes chlorine. My fear with turning the chlorinator on in high speed was that if the output of chlorine went up because of the high-speed, and in cooler/less sunny months the heater would run more, that my chlorine could quickly get high with a temperature drop. But if the output is the same, I will just need to to adjust the chlorine % just a little. And more chlorine consumption because of the higher water temperature balances a little the less chlorine consumption because of less UV in the cooler periods.
    Would you guys agree that I should have the system settings changed to run the chlorinator in high-speed mode too?
    15.5 k gallon. IG. plaster. Pool/spa pump: Jandy Zodiac FloPro FHPM 2.0-2 (0.25 and 2.0 HP 2-speed). Water feature pump: Jandy Zodiac Stealth Pro Series, SHPF 3.0 (3.0 HP). Filter: 250 SF cartridge. Surface area 290 SF. Jandy AquaPure SWG and PureLink. Aqualink controls. Jandy Legacy Pool and Spa Heater by Zodiac 400,000 BTU - natural gas. Heliocol solar panels. Built 3/2013.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: new Solar Heater - questions about Chlorine Usage and SW
    Pump speed doesn't matter for swg chlorine production, unless the flow is too low for the swg flow sensor. I would run the pump on high when solar heating, and on low for the rest of the time.
    38,246
    Quote Originally Posted by linen
    That is what I do
    Feb 2010
    South Florida
    73
    Thanks, guys.
    Any ideas about chlorine consumption, whether it's just UV that consumes the chlorine in the pool, or whether heat from a hotter (solar heated) pool is an additional factor in determining chlorine consumption?
    38,246
    Chlorine is consumed by 2 things. The sun and organics in the pool. The water temp changes the ability of stuff to start growing, you will need more chlorine when the water is warmer.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Keep an eye on your stabilizer, cyanuric acid, as well. It helps protect the chlorine. You also need to make sure your pump runs enough hours for the chlorinator to create enough chlorine for the pool.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    mas985's Avatar
    Pleasanton, CA
    11,737
    Water temperature is also a factor in chlorine consumption. It is discussed in this this thread: pool-water-chemistry-t628.html
    Mark
    Feb 2010
    South Florida
    73
    thanks
