Thread: got my test kit
    got my test kit
    Got my tf100 and want to make sure I'm doing right. Todays readings are
    ph 8.2+
    FC 7.5
    CC 0
    TA 160
    CYA 30
    CH 550
    I am shooting for for TA of 125 to bring csi to zero with the calcium hardness of 550.
    I have been adding Muriatic acid everyday and cannot get ph reading lower. I don't recheck for 24 hours, heat on 96 so it would be circulating overnight and possibly raising ph, is that right? Also, how much chlorine should I lose overnight at 96 degrees with these readings? Am I on the right track, should I be looking at borates, etc? Thanks for the help
    Bullfrog Spa 552, 411 gal no swg or uv
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: got my test kit
    Welcome to tfp, longtimenoob
    ph above 8.2 will read as 8.2, so it is possible you are a bit higher. I would dose with Muriatic acid to lower your ph from 8.2-7.2, then let the pool circulate for an hour, then retest, recalculate and redose. Repeat this until you a ph that is somewhere between 7.2 -7.5.
    Quote Originally Posted by longtimenoob
    No more than 1 ppm at night when the sun is off the pool.
    Borates are optional and I wouldn't look at them until you find you have a need for them. Get the rest of your parameters in order first.
