Results 1 to 10 of 10
Thread: 2.0 hp pump for above ground Pool?
    Hello, we have a HP 1.5 pump. Should we go to a 2.0? And I really thought I would just stick to the Hi Flo name brand since it has lasted for over 3 yrs. Don't know about other brands. Any suggestions? BTW I forgot to add to my profile that it is a salt water above ground pool as well. Thanks in advance!
    Murchison TX
    Cornelious AG Pool Salt Water System
    16' X 32' 54 in.
    Sand Filter Hi Flo Pump 48 Frame HP 1.5
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: 2.0 hp pump for above ground Pool?
    Hi, welcome to TFP! Usually we recommend a 1.0 hp pump or a 2 speed pump for a pool the size of yours. Is there a reason you are considering a stronger pump?
    Love TFP? Become a
    TFP Supporter!
    Thanks for the fast response. Our pump just went out, so I need to get my hands on one pretty fast. Have been looking online to purchase one.
    Murchison TX
    16' X 32' 54 in.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I agree with zea, for your pool I would go with a 3/4 to 1 hp 2-speed such as the pentair dynamo, or the hayward matrix.
    What is wrong with your current pump? Does the motor not start?
    the motor is not starting. My hubby wants to know what is the difference between a 1 speed and a two speed.
    Murchison TX
    16' X 32' 54 in.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Another vote for 1 hp 2 speed. I have a Hayward Powerflo Matrix 1 hp 2 speed. It's plenty of pump for my pool.
    1 you'll save money on electric with a 2 speed running on low speed most of the time for general filtration. Youl'll also get better filtration on low as your moving the water thru the filter slower. You can use high speed for better skimmer action and for mixing chem's after you add them and for vacuuming.
    Jeff
    will it matter that my filter isn't a Hayward or Pentair?
    Murchison TX
    16' X 32' 54 in.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Nope
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I'm pretty sure the pump doesn't care who manufactured the filter. Just as long as everything mates up.
    Jeff
    Thanks, yall rock!!!
    Murchison TX
    16' X 32' 54 in.
