Green water and funny testing results.
smithp
31
Just back home from Afghanistan. Thanks to all the help you gave my wife while gone.
Question about test kit results. Trying to perform TA test. 25 ml of water in cylinder. Added 2 drops of r-0007. Water stays clear. Add 5 drops of r-0008 and mixed and solution turns red-pink. No green or blue as the instructions say. ????? Is this a bad test kit or are the results that far off?
Fc-9
Cc-0
Cya-100
PH <6.8
It sounds like you wife was using trichlor pucks (or dichlor granules) again after we last "talked" to her. Until you/she stop using chlorine sources that add cya to your water, you will continue with this cycle of needing to drain the pool often. See: http://www.troublefreepool.com/pool-school/types_chlorine_pool
Deal with the ph/TA first, but then I would do another partial drain refill to get your cya in check.
