Thread: Green water and funny testing results.
    Just back home from Afghanistan. Thanks to all the help you gave my wife while gone.
    Question about test kit results. Trying to perform TA test. 25 ml of water in cylinder. Added 2 drops of r-0007. Water stays clear. Add 5 drops of r-0008 and mixed and solution turns red-pink. No green or blue as the instructions say. ????? Is this a bad test kit or are the results that far off?
    Fc-9
    Cc-0
    Cya-100
    PH <6.8
    IG-vinyl liner, 39,000 gallons, Hayward 1 1/2 hp super pump, Sand filter (not sure on flow)
    Locale - NE Texas
    22,542
    Re: Green water and funny testing results.
    That means that your TA is very low. You need to add enough washing soda to get the pH up to about 7.2 and then test it and the TA again. It may take several adjustments to get it into range.
    There are extended test kit directions available. Here is the post that describes the TA test: extended-test-kit-directions-t25081.html#p206395. As Dave stated, you'll get pink, red, or yellow with a TA of 0 and a low pH (which you also have).
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It sounds like you wife was using trichlor pucks (or dichlor granules) again after we last "talked" to her. Until you/she stop using chlorine sources that add cya to your water, you will continue with this cycle of needing to drain the pool often. See: http://www.troublefreepool.com/pool-..._chlorine_pool
    Deal with the ph/TA first, but then I would do another partial drain refill to get your cya in check.
