Thread: Balancing water before closing....HELP!
    Next spring I plan to drain/refill my AGPool (various reasons). I think I have algae in my pool b/c I have a brown substance that settles on the bottom yet clouds up when it gets stirred around. My question is since I plan to drain/refill the pool in the spring can I just close my pool even though I suspect algae? Do I have to add any "winterizing" chemicals since I will be draining the water next spring?
    18x48 Intex Ultra Frame
    22,548
    Re: Balancing water before closing....HELP!
    It's really a personal choice. If you're going to drain it anyway you can just close it and leave it. I wouldn't add anything except bleach.
    How much bleach? It's a 18ftX4ft.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What is your cya level?
    To be honest....I've never really been able to get a CYA reading but my chlorine has been fine all summer. I have a SWG so maybe that's why.
