Thread: little help on pH level and total alkalinity please
    Sep 2013
    San Diego, California
    21
    This may be a dumb question but my excuse is I'm new.
    My pH is 7.2, a little low I understand.
    But my total alkalinity is 120 ppm a little high right?
    Does that make sense? Item 1 tells me I need to add soda ash but item 2 tells me to add acid. Isn't that contradictory?
    any help gratefully received.
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    5) Flow rate of filter; 120
    Location - San Diego, California
    Re: little help on pH level and total alkalinity please
    7.2 is good. As long as your PH doesn't go down any further you can leave things alone and the PH will tend to go up on it's own.
    Note: If you are using trichlor tablets, the above does not apply and you should raise the PH with soda ash. The recommended TA is higher when using trichlor.
    Sep 2013
    21
    Thanks for the reply. I just googled trichlor and found out what it is and yes I'm using it so I should use soda ash.
    However, should I add acid to lower TA?
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
    38,235
    Really what you should do is stop using trichlor before your CYA gets to be unmanageably high. Read these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    What is your current CYA? Post up a full set of test results.
    EDIT: And no you should not add acid ... it lowers pH and TA and your pH is already at the lower limit.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Spiny Norman
    The trichlor you are using is very acidic and will lower TA and ph, that is why you should use washing soda to raise ph now (it will also raise TA up a good bit). As jbliz said, long-term a better solution is to move away from the trichlor pucks.
    Sep 2013
    21
    Thanks guys I appreciate the help
    1) 14,000 gals
    2) DE filter
    3) In ground
    4) concrete
