Buried Above Ground Pool Questions
TChess
Sep 9, 2013
8
Dallas, Texas
Hello,
I live in Dallas, Texas and am in the process of partially burying a 18' X 52" round Intex Sequoia pool. The pool will be exposed 8" above ground with all areas above ground covered with tar paper. The hole has been dug and the ground is level. The contractor will be installing the pool in 3 days and I have a few questions.
1. Should I install an additional liner on top of the included one, just in case?
2. Should I backfill with a slurry of concrete and sand rather than dirt?
3. The GFI plug is 15' from the pool, should I have a GFI outlet installed closer to the pool pump?
4. Will the (2) 35 watt submerged pool lights require individual GFI outlets or may I plug the lights and pool pump into the same 4 plug GFI outlet? :cry:
Thanks for the help
Perhaps someone will. If they don't, I'll wing it. If it doesn't work out, at least I gained a few valuable skills that may be useful in the future. My next project is an outdoor kitchen. Plan on using freestanding kichen components from the cardboard furniture store (Ikea). However, I need to learn how to weld. I asked one of the guys about teaching me and he laughed and said senorita no weld. Ha ha ha
TChess said:
Hello,
I see no benefit to having a second liner.
I wouldn't use concrete, dirt will work just fine.
That depends on what your JHA (jurisdiction having authority) says and/or where the equipment is going to be.
Your pump should be on a single outlet. Your lights can plug into the same circuit, but it should be different from the pump.
Thanks for the help
