Results 1 to 11 of 11
Thread: Buried Above Ground Pool Questions
    Sep 2013
    Dallas, Texas
    8
    Hello,
    I live in Dallas, Texas and am in the process of partially burying a 18' X 52" round Intex Sequoia pool. The pool will be exposed 8" above ground with all areas above ground covered with tar paper. The hole has been dug and the ground is level. The contractor will be installing the pool in 3 days and I have a few questions.
    1. Should I install an additional liner on top of the included one, just in case?
    2. Should I backfill with a slurry of concrete and sand rather than dirt?
    3. The GFI plug is 15' from the pool, should I have a GFI outlet installed closer to the pool pump?
    4. Will the (2) 35 watt submerged pool lights require individual GFI outlets or may I plug the lights and pool pump into the same 4 plug GFI outlet?
    Thanks for the help
    8247 Gallon, AG, Clear Saltwater, 18' X 52 round, Wood Grain Sequoia - Buried
    Built - September 2013
    Re: Buried Above Ground Pool Questions
    I dont have any answers to your questions but would like to see some pics of the process if at all possible!!!
    Intex 14x48 Ultra Frame 4,600 Gal
    1,000 gph Intex cartridge filter
    TF-100
    Savannah, GA
    Sep 2013
    Dallas, Texas
    8
    I live in Oak Cliff in Dallas in a very old house built in the mid 60's. I started with an empty backyard and dream.
    Pics. are in succession of progress with the final pic being current state after dig
    https://www.dropbox.com/sc/qrkrpen2qiwxufa/CR98td4Byh
    Sep 2013
    Dallas, Texas
    8
    Sep 2013
    Dallas, Texas
    8
    Other site pics.
    https://www.dropbox.com/sc/c16syktnfzygkdh/rK9OH4Pf1m
    Pool is between trees and gazebo is to the right of pool
    Sep 2013
    Dallas, Texas
    8
    BTW labor is very inexpensive here in Texas
    Pool = $600.00
    Dig Hole, Level, and Install = $1,000
    Supplies = $300
    Hopefully someone will answer your questions soon. But i really want to see the finished project
    TF-100
    Savannah, GA
    Sep 2013
    Dallas, Texas
    8
    Perhaps someone will. If they don't, I'll wing it. If it doesn't work out, at least I gained a few valuable skills that may be useful in the future. My next project is an outdoor kitchen. Plan on using freestanding kichen components from the cardboard furniture store (Ikea). However, I need to learn how to weld. I asked one of the guys about teaching me and he laughed and said senorita no weld. Ha ha ha
    22,551
    Quote Originally Posted by TChess
    Hello,
    I see no benefit to having a second liner.
    I wouldn't use concrete, dirt will work just fine.
    That depends on what your JHA (jurisdiction having authority) says and/or where the equipment is going to be.
    Your pump should be on a single outlet. Your lights can plug into the same circuit, but it should be different from the pump.
    Thanks for the help
    Sep 2013
    Dallas, Texas
    8
    Drag.az's Avatar
    Apr 2013
    Amarillo, Tx
    40
    That turned out really nice. I know this thread is a month old but, I did the same and did not have to deal with trees that close.. I bet that was ****.. would like to see more pics, you got anymore ?
    13k - Martinique 15x30 52"
    Sta-Rite crystal flo 22" sand filter & 1.5 spl rated
    Gorilla pad / waveless wall foam / foam cove
    Buried 2ft TF-100, TFPC
