Results 1 to 19 of 19
Thread: Need advices on balancing my water
    Sep 2013
    Orange County, California
    25
    This is the test result on 9/13/2013
    FC: 5
    Salt: 2500
    CYA: 15
    TA: 130
    pH: 8.0
    I added 10 oz of dry acid to lower my TA and pH. Added 16 lbs of salt too because i wanted it to be at 3000. Also added 3 qt 15 fl oz of instant pool water conditioner from leslie's to raise CYA. I tested it again today and here are the results:
    FC: 5
    Salt: 3300
    CYA: 20
    TA: 200
    pH: 8.0
    My added dry acid yesterday to lower my TA and pH but it went up even more...so I am confused . I guess I added to much salt so I just put some more fresh water in to offset it. I went ahead and added another 10 oz of dry acid today hoping it will go down tomorrow. Did I do something wrong? my water is looking fine and I hope it stay that way when I go outside tomorrow .
    Intex AG 16ft x 4ft, 5061-gallon
    Cartridge filter-1,500 GPH using it with intex saltwater system CS8110
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need advices on balancing my water
    What are you using for a test kit?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Your CYA level needs to be 70-80 for your SWG.
    Look at this to lower your TA pool-school/lowering%20total%20alkalinity. A lower TA will slow your PH from raising quickly. What's the TA of your fill water?
    Jeff
    Sep 2013
    25
    I used the tf-100 kit
    Edit: I haven't bother to test the TA of my filling water. Only got the test kit yesterday.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Are you certain you used dry acid and didn't accidentally use borax (or Baking soda or Washing soda)?
    Did you add any water to the pool?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Test your fill water TA.
    Jeff
    Sep 2013
    25
    yes I used dry acid. I bought that at leslie's. I added water in today after the second test to offset the salt level.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How much water did you add? What is your fill water TA and ph?
    Sep 2013
    25
    Quote Originally Posted by pwrstrk
    will do in the morning. It's dark out right now and I don't want to battle with bugs and mosquitoes
    Sep 2013
    25
    Quote Originally Posted by linen
    I am not sure how much water I added. I just used garden hose and stood there for 10 minutes . I will do those tests tomorrow and report back. I didn't know that you need to test the fill water first before messing with the pool water. I am very new at this so I went to Leslie's when I first filled up the water. I brought a sample of my garden hose water with me but they told me I have to shock the water first with Chlor Brite Granular Chlorine bag that they sell. I did that and added salt in and went back to them with the water to test it. They told me I shouldn't have shock the water since I am using the saltwater system and that is why my pH is high and too much chlorine. I told them it was them who told me to shock the water and walked out. Glad I found this site and found out about TF-100 kit so I can test it myself instead of relying on them.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Some fill water can be very high in TA, especially private well water. My well water is usually above 300 ppm TA with a high ph as well.
    Sep 2013
    25
    my fill water pH is 8.1 and TA is 98
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How do you get a ta of 98 with the tf-100?
    Sep 2013
    25
    oops I mistyped that. It's 90 . Didn't have much time yesterday to sit down and type so I just typed it real quick and went outside to do yard work and cleaning my pool.
    Sep 2013
    25
    This is my newest test:
    FC: 5
    Salt: 3200
    CYA: 50
    TA: 100
    pH: 7.4
    Would it be a good idea to mess with the water and try to bring CYA up? or should I just leave it be? Also should I let the filter and saltwater system run at night or in the morning (does it matter at all)?
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    With a SWG pool, its usually recommended that you bring your CYA level to around 70ppm and target a FC level of 5 and never let it fall below 3. I'm no expert on SWG's but I don't think it would make any difference whether you're running the pump and SWG at night or in the daytime as long as you can maintain those levels of FC. I believe however that it is also recommended that you split your pump run time into 2 equal sessions per day in order to help with skimming debris off the surface of the pool, so you may want to factor that in when making your decision.
    "The early bird might get the worm, but its the second mouse that gets the cheese." ~ W. Rian Adams
    Relative's IG Vinyl | 16x32 | ~18,600 gals | Hayward 3/4hp Pump | Hayward S244T Filter | Pentair Model 300 Chlorinator (not used) | Polaris 180
    Sep 2013
    25
    any stabilizer you recommend? I got my first liquid conditioner at leslie's and those are so expensive....$36 I think.
    Jeetyet's Avatar
    Jul 2012
    Florida Panhandle
    200
    I've seen several endorsements for the granular HTH brand at WalMart. Just make sure you get the one thats full strength. I think I saw it mentioned that they also carry one thats only about 50% CYA, but only slightly cheaper. Otherwise, as long its near 100% CYA and not some "magic blend" of various chemicals let price be your guide. As you've seen the liquid is rather expensive so stay with granular.
    Sep 2013
    25
    cool thank for the advices everyone
