Thread: To close.. or NOT to close... that is the question!!!
    28,600 gal IG vinyl in STL Missouri. We had a hot wave last week of a few days reaching 100, but now we are having highs in the low-mid 80s (soon to only reach the 70s), and the lows now are mid-40s (last night was 45 degrees). Pool temp at 8am was 74, and at 6pm was 81. We are scheduled to be cloudy with possible rain the next few days... and our neighbor has a nearly full-size River Birch tree RIGHT next to our fence/deep end of the pool, which has already started shedding leaves. We have also noticed a sudden increase in a "green dust" coating the bottom & some sides, as well as along almost all major seams. Our BBB numbers have been perfect, so I'm a tad confused on that one.
    I have read Pool School & all the posts suggesting we wait to close til water is in/below 60 degrees, but with the cruddy weather ahead, and it already too cold for anyone to enjoy swimming, what would be the best immediate plan for us?? Should we go ahead & put the mesh cover on - maybe not locking all the grommet thingys down yet - and continue testing/treating until its below 60?? Or should we super shock, shut her down, winterize & start the countdown clock for Opening Day??
    Our biggest question, I suppose, is other than the colder temps preventing algae, what are the benefits of waiting? We're attempting to weigh the cost differences of continuing to run the pump without swimming.... or potentially having to add extra chemicals to remedy green water? Last year, we were warm all thru September & closed early October (dont know any temps or test numbers.. I was a total dumb rookie then). We then opened late April, and the water was nearly perfect.
    We're torn & really can't decide. Any suggestions, thoughts, ideas or concerns will be much appreciated!!
    Thanks so much!!!
    Cathy
    28,600 gal, IG vinyl, St. Louis, MO - Installed: 09/2012
    Pump: 1.5 hp Pentair Challenger, Filter: Pentair TR-100 sand, SWG: IntelliChlor (Pentair) Vac: 2-wheel The Pool Cleaner, Test Kit: TFT100 kit, Salt Test: Taylor sodium chloride drop test.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: To close.. or NOT to close... that is the question!!!
    Quote Originally Posted by Cathy9887
    I favor this approach over closing now. Even in STL, I think it is way too early to close now, especially with water temps in the upper 70's-low 80's. Even if you get a couple of cloudy and rainy days, I'm still seeing a lot of upper 80's and even a 90F day or two later this week forecast for STL.
    Last year, we were warm all thru September & closed early October (dont know any temps or test numbers...We then opened late April, and the water was nearly perfect.
    I think this statement says it all. Not sure when the 60F water temperature will be reached and crossed, but STL can get plenty of warm days throughout much of September and into early October. This process apparently worked well for you last year and I wouldn't try to fix what isn't broken.
    This may or may not be algae and is also a reason why we like to see test results and/or pics.
