Results 1 to 9 of 9
Thread: Need help using TF-100
    I just got the TF-100 kit and started testing my pool that has been cloudy for several weeks. But I'm a bit confused. Per the basic test, total chlorine is above 5. When I do the Chlorine Drop test, FC and CC is 0. How can that be?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Need help using TF-100
    How are you doing the DPD-FAS test?
    Check this out, and see if you get different results......extended-test-kit-directions-t25081.html
    38,452
    Welcome to TFP!!!
    How much water and how much powder did you use when you did the FAS-DPD test?
    I followed the Chlorine Drop Test instructions in the TF-100 kit. Reading the link provided by Charlie_R, maybe I need to add another scoop of R-0870 powder. I will try that.
    Also, how do I test for CYA that's higher than 100? I can't seem to find a post on that.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Mix equal parts of pool water with tap water (which contains no CYA). Then using that water perform the test and double the result.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Also, how do I test for CYA that's higher than 100? I can't seem to find a post on that.[/quote]
    You can combine pool water and tap water in a 50/50 mix. Add that to the proper fill level then add your reagent. Your result would then be doubled.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Using 2 scoops of R-0870 did the trick. My FC is 35 and CC is 0.5. Now I have to get an accurate reading of my CYA which I know is above 100. I will do the 50/50 trick. Thanks for the help.
    38,452
    Do the 50/50 as described. If the reading is STILL near or over 100, dump out half of the mix and add more tap water, mix and retest multiplying the result by 4 ... you will lose accuracy, but should give you a little better idea.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by lipool
    Just thought I mention:
    If your FC +CC is actually 35.5, the OTO should show a dark orange or brown, not yellow.
