Results 1 to 11 of 11
Thread: Temperatures
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Temperatures
    So it has been colder here the last couple days. Over night low 40's and right now it is 68. Just checked the pool and it is 80 degrees. (The lowest reading ever since installing the pool in July) In the next few days it will get up to around 74 and sunny. With a solar cover on, is there any chance the water will heat up higher than it's current 80? I didn't know if the solar covers add much heat or really just hold the heat. When I lifted up the edge to put bleach in it, it seemed the air felt warm. Just trying to decide if there is a chance to swim again with warmer water, or if I need to try the chilly 80 one last time. Thought or experiences????
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Temperatures
    It might go up a couple of degrees. Don't hold out for the high 80's -90's cause it won't happen unless you get some hot weather. The sun angle is down too.
    Solar covers are better at retaining heat although they will increase temp some.
    Jeff
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,570
    Re: Temperatures
    I got about 3 degrees to spare here in Texas if that will help ya' any! 84 is a good "hope for" target I think.
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Re: Temperatures
    I just wasn't sure if the outside temperature would have to be in the 80's to get the water to go up a little. Hopefully I can find at least one more day in the next week that I can get in before I say goodbye for the winter.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Temperatures
    For the most part, solar covers just hold the heat in, mostly by preventing heat loss due to evaporation.
    We still swim down to about 72 in the fall (kids will go in briefly at lower).
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Re: Temperatures
    Quote Originally Posted by linen
    Not sure I can handle 72. I get in very slowly even at 80.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Temperatures
    Quote Originally Posted by brmommy
    There is your problem...you can't go in slowly at those temps, you have to do it fast like taking off a stuck bandage
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Temperatures
    Yep, just jump right in !!
    Jeff
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Re: Temperatures
    It dropped to 79 today. Being afraid it might be my last chance, I got in. It wasn't too bad once I got used to it. Still hoping for some sun this week to warm it up for maybe another swim or two. First year with a pool and I'm not ready to close it yet!!!!!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Temperatures
    Our recommendation is to not close the pool until the pool temperature is consistently below 60F and open before the pool temp gets consistently above 60F. This minimizes opening cleanup.
    Also, sometimes an "Indian summer" will surprise and get the water warm enough to swim later in the season.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Temperatures
    I got in today to do the last vacuuming and brushed the walls. Water temp was 78. Wasn't bad.
    Cover went on cause the leaves are starting to fall and I don't want to have to deal with them. It was a good swim season !
    Jeff
