Thread: 15 000 gal for $139 INTEX SWG
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    hi guys
    I plan to buy a Intex AGP 24x12x52 approx 8500 gal from Amazon, but I don't think they come with a good SWG so I found this in walmart 15 000 gal for $139
    http://www.walmart.com/ip/Intex-Krystal ... n/19336123
    Do you think this is a good choice?
    Is there a better Intex alternative for the price?
    what kind of INTEX sand filter will be a good match?
    thanks in advance
    Luis
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Re: 15 000 gal for $139 INTEX SWG
    That SWG will be fine. To do better than that you need to spend well over $400.
    I recommend getting an Intex sand filter and pump combination. If your electric rates are high (above $0.20/kwh) it is worth looking into a two speed or small variable speed pump, which will cost more up front, but save a great deal in electrical costs. At lower electric rates, the Intex sand filter/pump combo is a better deal.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    hi Jason or any contributor
    It is the separated INTEX sand filter the one that I want to match, the bigger the better, right?
    so what sand filter will be?
    WOW!!!
    I just found a better price in amazon
    http://www.amazon.com/Intex-54601EG-Kry ... d_sim_lg_1
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    The intex 2650 sand filter has gotten great reviews.
    The swg you posted the link too should work fine. Make sure when you use it to disconnect the wire to the copper bars (second wire from the right of the link you posted just above).
    Avoid the all-in-ones that have the swg and sand filter combined...the pump and the swg never fail at the same time.
    I have a similar intex swg on my permanent 21' agp and it works great (on it's third year of life, though I think I will need to replace it next year).
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Yes, I will buy them separately.
    Thanks
