Thread: Taking the pool down for the first time: questions
    I've read several posts, but I have a few remaining questions:
    I have a 14' ultra frame, with in wall skimmer and 2650 sand filter. I'm in Wet and mild Oregon, not worried about freezing.
    Should i remove the wall skimmer? Undo all the screws?
    Scrub -> drain -> dry -> storage? I'm leaning towards stuffing it in a rolling garbage can, will buy something once I start rolling it.
    We made a gravel/sand foundation... I'm curious for options on how to preserve this? We don't use the backyard much, but don't know how fragile it will be. 3" of -1/4 and 1" of river sand.
    What's the process for the sand filter? Do I need to remove the sand after draining it? I'm planning on covering it, but leaving it outside under a roofed section.
    Any other thoughts?! Taking it down as we feel it will be better protected from our kiddos that way.
    DigbyAllen's Avatar
    Westchester, NY
    113
    Re: Taking the pool down for the first time: questions
    I took my Intex pool down last September and plan to do so again this year. I live in NY so I do worry about freezing.
    I don't have a wall skimmer so I can't answer that question.
    My 2650 sand filter is new this year, but what I plan to do is drain all the water but leave the sand in, and store it in my basement. I have a walk out basement so it's easy to access without struggling down stairs. I also store the pool liner in the basement. The rest of the pool i.e. poles, ladder, hoses, etc. I store outdoors in my shed.
    I also have a gravel/sand base. I left the blue Intex tarp on the sand and put stones all around the edges to hold it down. When Hurricane Sandy roared through last October I thought it would rip the tarp off and blow it away, but surprisingly it held up with no problems at all. You can see a million leaves down but the tarp is intact.
    [attachment=1:wltn3dbg]DSC01360a (Large).jpg[/attachment:wltn3dbg]
    By the end of the winter the tarp was dirty but still in good shape. When I put the pool up this year I only needed to put down 4 bags of sand to fill in a couple of spots where some sand washed out, and then re-level.
    [attachment=0:wltn3dbg]DSC02645 (Small).JPG[/attachment:wltn3dbg]
    Next spring I plan to put some foam boards down over the sand as many here recommend.
    Jim
    Intex 15' x 42" -- 4,000 gallons
    installed August 2012
    Intex 2650 sand filter, Hayward skimmer
    TF-100 test kit, TFP method
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Nice job !!
    Jeff
