Thread: Cloudy Water
    Apr 2013
    NJ
    57
    Cloudy Water
    Pool was just completed about 10 days ago has been filled since and filter has been running 12-18 hours a day everyday since trying to balance water and clear it up. The water chemistry is pretty close I think but I am still moderately cloudy which you can really see in the deep end. At night with the light on you can see very small particles throughout the water. Looking for advice before I try and solutions.
    Pool: 24,000 gallons vinyl, VS pump,, IC-40 SWG, sand filter.
    PH: 7.5
    CL: 6.0 (high I know, but coming down)
    CC: 0.0
    TA: 90
    CH: 140
    CYA: 20
    Salt 2800 PPM.
    24,000 gallon vinyl, 2 main drains, 2 skimmers, 4 returns, 2 inch pipe suction, 1.5 inch return. Pentair VS pump, Pentair IC-40 SWG, Pentair SD-80 filter. TF-100.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Cloudy Water
    You may just need some more filter time. A sand filter will filter better when it gets a little dirty. If it still won't clear you can add a little DE to the filter. pool-school/add_de_to_a_sand_filter
    Your CYA level should be 70-80 ppm for your SWG.
    What test kit are you using ?
    Jeff
    Apr 2013
    NJ
    57
    Re: Cloudy Water
    Using the TF 100.
