Results 1 to 7 of 7
Thread: PH doesn't go down?
    PH doesn't go down?
    I'm having the exact same issue! Gunite pool with luna quartz plaster and I'm constantly battling pH. My TA is at 90 too and I bring my pH down to 7.2 and within 3 or 4 days, my pH is at 8.2. Will raising my TA too 100 or 110 stabilize rising pH?
    17,000 inground gunite pool finished June 2013. Pentair variable speed something or another. Polaris cleaner, inline rainbow chlorinator. Using trichlor until CYA reaches 50-60.
    38,475
    Re: PH doesn't go down?
    No. It will make the pH rise faster. How old is the plaster? Do you have SWG or water features?
    I do have 3 sheer descents and a spillover on the spa tat is about 6' across and an 18" drop from the spa to the pool level. It runs for about 6 hours a day. As I'm typing I'm kind of having a eureka moment. That's probably why ,y pH is rising right? Should I lower my TA at all, or just deal with acid twice a week? I loathe pouring in acid...I totally dread it because I have to hold my breath and try not to burn myself. I would love for my pH to stop dropping!
    Complete test today was:
    FC 3.0
    CC 0
    TC 7.0
    pH 8.2+
    CH 430
    CYA 50
    TA 90
    I poured in 4 cups of acid and I'm about to pour in a gallon of bleach. 17,000 gallon pool
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by Dreampool13
    FC 3.0
    CC 0
    TC 7.0
    This would mean your CC was 4, if it was 0 the TC would be 3.0.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    38,475
    Yes, the pH is rising due to all the aeration, lowering the TA may help.
    Mar 2007
    San Rafael, CA USA
    12,082
    Also, don't lower the pH to 7.2 since the rate of pH rise is faster the lower the pH. Just lower the pH to 7.5 only. Turn down the time you run these aeration sources. If you lower your TA significantly, if it helps, then you can consider using 50 ppm Borates for additional pH buffering.
    Also, the test sounds like it is not from a TFTestkits TF-100 or Taylor K-2006 test kit. If you don't have one of those, get one. You are flying blind if you are using pool store numbers since they are often wrong.
    That's interesting about the pH rising faster when it's lower! I never knew that and that will cut down on the acid I'm using by almost half! I'm going to try getting my TA to 80 to see if that makes a difference. I'd love to try borates but I have a dog that drinks the water so yeah...not a risk I'm willing to take. Thanks!
