Results 1 to 12 of 12
Thread: Life after SLAMing - what next?
    Aug 2013
    Dallas, Texas
    85
    Hi All,
    I finished SLAMing on Tuesday and now into maintenance mode. Pool water looks crystal clear but now I need to make sure I'm doing all the right things to avoid the pool creatures coming back.
    Results from testing today:
    FC 4.5
    CC 0.5
    TA 60
    CH 190
    CYA 50
    PH 7.5
    Question:
    1. I believe I need to keep FC up to maintenance levels
    2. are the other results accurate soon after SLAMing?
    3. If its ok to test TA, CH etc, then I need to add Baking Soda and calcium chloride.
    Thanks in advance.
    17500 Gallons, IG, Plaster, DE Filter, Built 1997, No Spa, Polaris 280
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Life after SLAMing - what next?
    Quote Originally Posted by onedah
    Hi All,
    FC 4.5
    CC 0.5
    TA 60
    CH 190
    CYA 50
    PH 7.5
    Question:
    Yes, keep FC between 4 and 8 and never below 4.
    Yes
    I suggest you go ahead and raise the TA to about 70 today.
    Tomorrow, you can increase the CH. It is recommended to raise the CH on a day that you are not adjusting anything else.
    Thanks in advance.
    You're done SLAMing when:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Swimming
    Aug 2013
    Dallas, Texas
    85
    Linen Absolutley spot on.
    Butterfly - thanks for the infor - I am adding Baking Soda today and will deal with CH tomorrow.
    Questions:
    1. I have noticed that I loose a lot of FC to the sun everyday - pool is in the sun most of the day - is it normal then to be adding quite a lot of FC to keep up (can get expensive)?
    2. We are away next week for 7 days and wondering what suggestions you have for maintainance while away, especially as the texas sun can eat FC up quickly?
    Thanks
    O
    30,424
    Questions:
    Thanks
    O
    What do you mean by a "lot" of FC loss?
    You may be able to use a puck floater. What is your CYA level? A week is a long time to expect a pool to remain pristine without attention.
    Aug 2013
    Dallas, Texas
    85
    Questions:
    Thanks
    O
    What do you mean by a "lot" of FC loss? I'm adding about 50oz of bleach a day to keep fc levels, I loose about 3 - 4 ppm a day
    You may be able to use a puck floater. What is your CYA level? CYA = 50, do I avoid using the Chlorinator?
    The chlorinator has the exact same downside as a puck floater: the pucks add CYA. I see from your other thread that you're already acquainted with the drain and refill process for lowering CYA if it gets too high.
    You can see how much chlorine and CYA the pucks will add by using the "Effects of adding chemicals" section at the bottom of the poolcalculator.com page. From there, you can decide if using the chlorinator is the route you want to go while you are away.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    1. A "typical pool" at 50 ppm cya might lose about 40% FC to the sun each day.
    2. Best way is to have someone come and dose for you daily or every other day. If you do not have that option, then if you have a cover, you could bring the pool up to your SLAM level, circulate it, then cover it, and cross your fingers until you are back. If you use a puck chlorinator, you may have to do a drain/refill again at some point.
    Aug 2013
    Dallas, Texas
    85
    Thanks for the suggestions.
    I dont have a cover or the option of someone coming by every other day. I will have to take my chances with Pucks.
    Has no one created Chlorine tablets which dont have other chemicals in them, or a chlorine release system without all the other affects.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Nope, the other chemicals are required to make the dry form of chlorine.
    I'm not sure how broad of an answer you're looking for when you say "chlorine release system". There is the option of installing a salt water generator (SWG) system (automatic-chlorinators-swg-liquidator-etc-f21.html), or a chlorine injection system (chemical-automation-and-the-liquidator-f81.html) if you're looking beyond this particular travel need. Each has its own pros/cons to consider, but they don't add CYA or CH the way the solid forms of chlorine do.
    Aug 2013
    Dallas, Texas
    85
    For now I will go with the pucks and hopefully all will be good when we get back.
