Results 1 to 9 of 9
Thread: I left the fill line on ... AGAIN
    Jan 2013
    Houston, TX
    1,079
    not sure how many thousand gallons I dumped overnight. Does anyone have any experience with the Poolmiser Smartmiser? My fill line is setup in such a way that it would be an easy install. I'm planning to get a traditional autofill when I get the plaster redone in a year or 2.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: I left the fill line on ... AGAIN
    I opted out of the Autofill for my build simply because I want to know at earliest if there is a problem. Every builder has tried to convince me otherwise, but I'm outdoors all the time and think I can handle it. That said, I have left a sprinkler on at night when I shouldn't have, so I'm not beyond forgetting something.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I've done that twice. Only one time did it overflow. Now I set the timer on the stove when I turn on the water as a reminder to check it.
    Apr 2008
    Central Texas
    326
    Put one of these on your fill hose:
    http://www.amazon.com/Melnor-101-Flowme ... B00176FFJC
    Dial in how many gallons you want and then it will turn itself off afterwards.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I like it Harry, that is a good idea.
    Essential Links:
    Jan 2013
    Houston, TX
    1,079
    Harry,
    Love the idea but my fill line is hard plumbed. ... I could just switch to the hose. Hmmmm.
    Jun 2011
    Long Beach, CA
    2,780
    I always set a timer on my phone, and keep it on me, since I overfilled twice to the coping. Hopefully I will never overfill again, it has worked for the last year.
    Jan 2013
    Houston, TX
    1,079
    I did the phone thing... left the phone in the bedroom ... oops.
    Oct 2013
    Adelaide, Australia
    77
    I did that twice last year.
    I recently made myself an "autofill" using a float valve for a side entry toilet cistern some adaptors and quick release hose fitting. Mine is mounted under the skimmer lid (probably not the best place to put it, but it looks neat). Much cheaper than buying them premade and it doesn't take any skill, just connect a pipe and set the float level.
    I don't leave the hose on it all the time, I usually put the hose in front of the return to circulate it, but when I need to I can leave the hose on my autofill while I do other stuff and not worry about overfilling.
    I'll post some pictures when I get home if anyones interested.
    Steven
    18.5k US gallon/69kl IG tiled with an Onga Pantera 25" sand filter, powered by a Davey Silensor 200 1HP/0.75kW pump coupled to a Zodiac TRi (mid) SWG K-2006C Test kit imported from the USA...
    in Adelaide, Australia...
