Thread: First Time
    First Time
    OK I just got my Taylor test kit and gave it a whirl....
    FC: 15 ppm (way too high right?)
    CC: 0
    pH: 7.9
    TA: 170 ppm
    CYA: > 100 ppm (I think the pool guy got a little carried away)
    Calcium Hardness: 230 ppm
    So I was thinking since pH is a tad high and TA is high, I would add ~ 2 cups of muriatic acid (it's only a 2000 gal spa, maybe even a little less)
    I think I just have to let the CYA go down with time from splash-out, etc... Is that correct?
    And I think likewise the FC level should come down with sunlight, which is abundant in our area at present. I was just going to turn down the SWG to minimal until FC gets back in line (which I think might take a while with CYA so high)
    Does that sound right? Am I way off on anything (or everything?)
    Thx!
    2000 gal Spa, IG, Hydrazzo finish, 2.0 HP Zodiac e-Pump, Jandy DEV48 DE filter, Jandy Aquapure SWG, Jandy LXI gas heater
    May 2013
    Bay City, Michigan
    283
    Re: First Time
    Okay so I did just notice this was for a spa, but everything is basically the same. A true CYA reading is still important, and being a spa, its easier to get REALLY high CYA levels.
    Quote Originally Posted by meliman
    Time to read pool school to understand the FC/CYA relationship. With CYA at 100 your target is 12 so 15 not even considered high in the slightest. The problem is if your test came out at 100, it is probably higher. Anything at or ABOVE 100 will read as 100. You need to redo the test with the diluted method.
    If your CYA level is 90 or higher, repeat the test adjusting the procedure as follows:
    Fill the mixing bottle to the lower mark with pool water.
    Continue filling the mixing bottle to the upper mark with tap water.
    Shake briefly to mix.
    Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark.
    Continue the test normally from step 3, but multiply the final result by two.
    PH tests with chlorine over 10 is not accurate. Your TA is high, but that MIGHT come down if you drain and refill, or it will come down over time as you control the PH rise with MA. Depends on your fill water.
    Since it is a spa, I would just suggest solving the problem right away and doing some drain and refills..(get an accurate CYA reading with the diluted test method and can re-evaluate just how high it is, and how much water would need to be replaced. (Had another member that got a 100CYA reading, ended up being like 270.)
    Your FC level is perfect for CYA of 100, but like previously said, it is likely to be higher.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Re: First Time
    Thanks so much for the advice. I will definitely go back and review my pool school! So much to learn
