Thread: Union threads -- Plasto Joint Stik or Silicon lube or both?
    Trying to figure out how to achieve leak-free union joints. I'm installing them on both side of the pump so that it can be easily removed if necessary. I've seen one You Tube video where the guy put Plasto Joint Stik on the threads going into the pump body (seems reasonable since this is basically permanent). But for the union fitting is it best to use Silicon lube (so it could be eventually undone)? And lube up the o-rings, too?
    Opinions?
    Thanks again,
    muski
    25,000 gallon IG plaster pool (c.1963). Pentair Intelliflo VS. Clean n Clear Plus 320. Pentair East Touch 4P. Intellichem with liquid chlorine dispenser. 8 Aquasol 4x10 Panels. Polaris 280 w/booster pump.
    30,431
    Re: Union threads -- Plasto Joint Stik or Silicon lube or bo
    The threads have very little to do with waterproofing a union.....it's the o-ring that makes the seal....the threads simply compress the o-ring so the two flat surfaces mate properly.
    You could certainly use lubricant on the threads if you wanted to but plastic doesn't corrode and, of those I have taken apart, a strap wrench is all I have needed.
    I don't know what plasto joint stick is but I would not consider the threads into the pump as permanent......I would suggest you use pipe dope.
    There is no real reason to lube the o-ring, either. If the union is installed correctly, the compression of the o-ring will seal the joint.
    May 2013
    NJ
    114
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
