Results 1 to 13 of 13
Thread: Does anyone use their hot tub as a cool tub in the summer?
    Jennica's Avatar
    May 2012
    NJ
    91
    I'm contemplating taking down our pool because I'm the only one that uses it these days. I'm toying with the idea of getting a hot tub which I would use a lot in the spring, fall, and winter. I was wondering if I would be able to keep the water unheated during the summer and use it to cool off. Is there anything that would prevent me from being able to do that?
    Thanks!
    15' Round Above Ground 5,300 gallons
    Cartridge filter
    Taylor 2006 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Does anyone use their hot tub as a cool tub in the summe
    As long as you keep the water sanitized and circulated it shouldn't make any difference whether you heat the water or not. You may want to place it in a shady area to help keep the water cool in the summer.
    Love TFP? Become a
    TFP Supporter!
    Jennica's Avatar
    May 2012
    NJ
    91
    Awesome! Thanks!
    Cartridge filter
    Apr 2009
    South Texas
    177
    I know on mine when the pumps run is when the water is heated. Just check before you get it to see the lowest temperature setting. I can take mine down to 75. The jets should still be relaxing!
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    We run ours cold sometimes...works great. Our pump and heater can be controlled independently, i.e. the heater can be turned off with the pump still on.
    Jennica's Avatar
    May 2012
    NJ
    91
    Good advice. Thank you all!
    Cartridge filter
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Mine even has a summer mode setting. We have often kept it unheated in the summer for our grand kids to play in although it still gets up in the mid 80s from the sun. I think our 3 year old grandson enjoyed the hot tub more than the pool that year. It was just enough space and water for him yet not scary deep.
    When my daughter was heavily pregnant and miserable in August we purchased large bags of ice so she could enjoy floating in the cool water.
    Jennica's Avatar
    May 2012
    NJ
    91
    That sounds great Yipee. We've got grandkids that age too and I think they would love it.
    Cartridge filter
    Jennica's Avatar
    May 2012
    NJ
    91
    The one I have my eye on, I'm not sure if the heater and pump run independently but the temp can be set for 80 degrees. So basically, when the thermostat is satisfied the pump will run without heating, right?
    Cartridge filter
    Jan 2012
    7,338
    I *think* so, it makes sense to me. But double check that with the sales critters at the spa store to be sure.
    Apr 2009
    South Texas
    177
    That's how mine works, the pumps come on periodically to circulate the water but the heater only kicks in to get it to the set temperature.
    We use ours cool all the time during the summer. The pump never turns off so water is always circulating. I turn the thermostat completely down and it gets to around 32C during the day or 27C at night. If it's too warm, I just siphon off about 1/3 of the water and then refill will cool water. VERY nice when the day temps are in the mid to upper 90's.
    Jennica's Avatar
    May 2012
    NJ
    91
    That sounds awesome!
    Cartridge filter
