Results 1 to 9 of 9
Thread: What is your favorite chemicals to clean the pool?
    Today there are several option out of chlorine like Bromine or Biguanide. I even heard that some people used hydrogen peroxyde.
    what do you use?
    For which reasons do you use this particular chemical?
    Thank you.
    38,248
    Re: What is your favorite chemicals to clean the pool?
    Welcome to TFP!!!
    I would guess that 95+% of the members here use chlorine. Because it is the cheapest and most effective.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, doud5
    In the US, there are only 3 approved sanitizers for pools: Chlorine, Bromine, and Biguanide. Hydrogen peroxide is not approved.
    Biguanide: You will find many posts here about algae, cloudy water, and the expense related to Biguanide. Most discussions on it, end up with the poster changing to chlorine. I sure wouldn't use it.
    Bromine: Can work but is more expensive and you will have to use more than chlorine due to the lack of sun protection. Also, imo the smell of bromine is not desirable.
    Chlorine: Is the easiest and cheapest method. Following the methods taught here on tfp will eliminate the issues people sometimes associate with chlorine (burning eyes, and "chlorine" smell).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP doud5!
    CHLORINE for me. The one and only thing.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP!!
    Liquid chlorine "bleach" is the only thing I will use.
    Jeff
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    When we say CHLORINE... we mean LIQUID CHLORINE for the vast majority of the users here, IMHO. Solid forms of chlorine (powder, granule, pucks) have other chemicals to bind the chlorine and the side effects of that binder can be adverse.
    -- Guy --
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Quote Originally Posted by doud5
    what do you use?
    Thank you.
    I use sodium hypochlorite. You can find it under the trade name as household bleach. I use it because all it adds other than chlorine is a little salt. I do not use anything with the word shock or magic or anything like that. I can't tell you the last time I had to raise my chlorine to fix a problem "i.e. shock my pool". Hope that helps.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Welcome Doud5. I use chlorine like most people except I make it at home using a salt water chlorine generator. It sure beats lugging chemicals and driving to the store. I did a ton of research and all methods other than liquid chlorine or SWCG try to explain why they are better. Trust me, they are not better. Sooner or later you will be using chlorine. Just search this forum for bigaunide and bromine and see what I mean. Good luck.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Welcome!
    Chlorine for me. I usually use household bleach. If I need to add CYA, I'll use a bag of the "shock" that I have from before I became enlightened. I don't shock with it, though; I just use enough to get the chlorine level up while raising CYA at the same time.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
