Thread: Closing Pool
    Closing Pool
    Hi,
    I'm thinking I will be closing our above ground pool for the first time. Last year was the first year we were taking care of the pool and had a pool company come out and close it. Anyway, I was going through the pool school instructions for closing the above ground pool, and just wanted to make sure I understood everything.
    First question is related to the below steps. Last year the company had me leave the pool at normal water height. And then I bought a skimmer gizmo and plugged the return. Would that be correct for the below steps? After using the gizmo and plugging the return, do I need to do anything to be able to remove both of the hoses from the pool?
    * Drain water to 6" below lowest return/skimmer opening and hoses/fittings removed.
    * Skimmer/return plugs or "gizmos" may be installed or they may be left open - this is a personal choice for each pool owner
    Next question related to the below step. I'm not sure if I have a multi-port/spider gasket. Would I not have one with a cartridge filter - do you need more information? Next, I'm just thinking, I don't really have any other smaller fittings, hardware or filter drain plugs. I think I just have the pump basket and the skimmer basket. Am I missing something?
    * Remove muti-port/spider gasket. Smaller fittings, hardware and filter drain plugs can be stored inside pump pot basket - lube pump pot basket with silicone lube. Remaining pump hardware can be placed inside gallon zip-lock bag and taped to side of pump.
    To sum up, the only thing I'm really doing for closing the pool is cleaning/going through the shock process - no problem. Putting the skimmer gizmo and return plug on. Removing the hoses, draining the filter - bringing that inside. And putting the winter cover on.
    Really appreciate the help!
    30' round AGP. Haywood X Stream cartridge filter.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Closing Pool
    We need to know where you live and how much freezing for recommendations.
    Re: Closing Pool
    Thanks for the response. I live in NJ. I would say freezing is a concern.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Closing Pool
    Did your pool hard freeze (solid block)?
    Here (mn) they do, so I definitely drain mine 6" below the skimmer, blow out all lines (I have buried hard plumbed lines), then I cap them. I leave my skimmer outlet open so that it can drain. I drain my pump and bring it inside.
    You probably do not have a multiport, since you have a cart filter. I have one on my sand filter, in that case I drain my filter and leave the drain cap off and set my filter to the "winterize" position that just leaves the valve cracked open.
    Re: Closing Pool
    Hi Linen,
    Thanks for the information on the multiport. The pool didn't hard freeze last year. But, I did drain the pump and bring it inside last year.
