Results 1 to 10 of 10
Thread: pump spewing water
    pump spewing water
    Help, i awoke this morning with water spewing from my pump. The water level was below the swimmer. I need to see if incandescent fix this myself to save money. Any feedback would be helpful. I posed pics and a video. Thanks
    24' x 52' Round AG 11,200 gal., 2 HP pump Cartridge Filter
    Re: pump spewing water
    Did the upload post? I don't see it
    22,553
    Where is it leaking from?
    38,475
    No pic or video was included in your post.
    it wont let me post the vidieo, saying 3pg is not allowed. posted the pics the leak is in between the silver and black piece.
    38,475
    That is typically a shaft seal that needs replaced ... or look for a go-kit that includes the shaft seal plus all the o-rings in the pump.
    Can't tell much from the pics but if it's leaking between the motor and the pump you probably have a shaft seal that has gone bad.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    thank you so much
    okay watched a lot a videos before i began taking the pump apart. everthing was fine until i got to the impeller. every video said the hold the back of shaft with screwdiver and twist the impeller counterclock wise, well nothing was happening. so i had to break it off, and to my suprise there were no threading on the shaft rod, looks like that impeller was a permanant fixture in the pump. so my question is has anybody every seen a pump like this. where as if something go wrong u just have to replace the whole pump. don't know if it's a waterway of millennium because both names on on the pump.
    found the threads under another lock nut... thanks for all of the help. i broke a part that didn't need to be broken. oh well i learned something today....
