Thread: aqua- trol by hayward
    Sep 2013
    indy
    15
    anyone know if these are any good, I was thinking about getting into this swg system next year
    13500 gal , above ground 24 round 52 deep, vinyl, 200lbs sand filter,, 1.5 hp one speed, aqua trol-rj
    38,524
    Re: aqua- trol by hayward
    It is basically the same as the Aqua-rite that many members use, but has the added time clock and simple electrical plug. The only thing is it is a little smaller for your pool than we would recommend.
    We typically say to get one sized for 1.5-3 times the size of your pool so you do not have to run it and the pump all day. That is sized for 18k pool which is 1.33 times the size of your pool. That just means you may have to run at a higher output % and/or for longer than a bigger SWG ... this also means the cell may not last quite as long.
