Thread: Flovis Flow meter & Booster pump
    Hi --
    I'm installing a Flovis Flowmeter in my new system. I figure it goes between my filter and solar loop. But I also need to put a T in there to feed my Polaris booster pump. Should I put the Flow Meter before or after the booster feed? Or maybe it doesn't really matter...
    Any opinions?
    muski
    25,000 gallon IG plaster pool (c.1963). Pentair Intelliflo VS. Clean n Clear Plus 320. Pentair East Touch 4P. Intellichem with liquid chlorine dispenser. 8 Aquasol 4x10 Panels. Polaris 280 w/booster pump.
    38,547
    Re: Flovis Flow meter & Booster pump
    Depends on what flow you want to measure ... through the main pump/filter or through the solar.
    I would probably put it after the booster line as the flow through the solar is more important.
    Well I was thinking I wanted to measure total flow through the pump/filter so I can correctly set up my Intelliflo VS? So I guess that would suggest I put the flow meter before the booster T.
    What would be the reason to measure flow just through the solar panels? So I don't send too much flow and burst them?
    Thanks for your advice.
