My pump leaks just a little. Just enough so that I see some visible water on the plastic base that the pump is mounted to. Not really enough to affect the level of the pool..as far as I know. I see that the pump seal can be replaced if the pump leaks. There are a few videos on U Tube as to how to do it. Looks simple enough. Are there any other issues that a pump might have to cause it to leak or is the seal the most likely culprit.
Thanks
Dan
Sent from my Samsung Galaxy 10.1 using Tapatalk
Thanks
Dan
