Thread: Hayward Pump Leak
    Mar 2013
    CT
    351
    Hayward Pump Leak
    My pump leaks just a little. Just enough so that I see some visible water on the plastic base that the pump is mounted to. Not really enough to affect the level of the pool..as far as I know. I see that the pump seal can be replaced if the pump leaks. There are a few videos on U Tube as to how to do it. Looks simple enough. Are there any other issues that a pump might have to cause it to leak or is the seal the most likely culprit.
    Thanks
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    38,371
    Re: Hayward Pump Leak
    The shaft seal is the most likely culprit, but for not much more $ you can get a go-kit that includes all the seals / o-rings in the pump that you could replace while you are in there.
    Definitely want to get it fix before the bearing suffer.
    Smykowski's Avatar
    Sep 2011
    3,065
    Agreed. If you're at all comfortable doing DIY jobs, it's an easy fix. You can find them online for $20-25 including shipping. What kind of Hayward pump?
