Thread: Greetings From SoCal
    Hi Everybody - wanted to introduce myself as I'm sure I'll be asking lots of questions. I have a new IG spa that we installed as part of a total backyard makeover (cabana with double sided stone fireplace outdoor kitchen, etc...). I was the 'pool boy' for our family pool back in the late '70s/early '80s, but haven't given any of this much thought in the past 35+ years. While some things haven't changed much (DE filters seem pretty much the same), a lot has changed - pool chemistry is a whole bunch more complicated (I used to pretty much pour jugs of hydrochloric acid and chlorine into the pool weekly), valves magically move by themselves, electronic control systems, and SWGs!
    I fired the pool guy after about 1 month, and plan to go it pretty much alone. Waiting for my Taylor testing kit to arrive today.
    Thanks in advance for your patience and help
    Brian
    2000 gal Spa, IG, Hydrazzo finish, 2.0 HP Zodiac e-Pump, Jandy DEV48 DE filter, Jandy Aquapure SWG, Jandy LXI gas heater
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Greetings From SoCal
    Welcome to TFP !
    Jeff
    38,235
    Welcome to TFP!!!
    Sounds like you are off to a good start.
    You know, the pool chemistry we recommend is a whole heck of a lot closer to the recommendations from many years/decades ago than it is to the current pool store recommendations. They will try to sell you all kinds of potions and elixirs while we get back to the basics of hydrochloric acid (muriatic) and chlorine (bleach). Although we recommend a little more testing and dosing than it sounds like you did in the past
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
