Thread: Algae but no cc's?
    May 2013
    Virginia
    75
    Algae but no cc's?
    Just wondering why I have an algae bloom but am not registering any cc's?
    I got a bit lazy with the cooler temps and kids going back to school (nobody using the pool) and got a slight algae bloom - water is greenish and cloudy. Of course I am slamming and brushing to take care of it. Yesterday when I tested I got ph 7.6, fc 5, cc 0, cya 40. Side note- since I bumped my CYA from 30 to 40 my chlorine levels have been holding a lot steadier; I find I need to use less bleach.
    Anyway, wouldn't I be registering some cc's?
    10,000 gallon inground, gunite, 500lb sand filter. Brand new to this pool thing.
    38,251
    Re: Algae but no cc's?
    Seeing algae does not = seeing CC.
    That is why there are more than 1 criteria to know when to stop the SLAM process.
    I take it you started the SLAM after that test result of only 5ppm?
    May 2013
    Virginia
    75
    Ah, I see.
    Yes, yesterday was very warm (90s) and kids wanted to get in the pool after school. I went ahead and let them (like I said, fc was 5), then started the SLAM process when they were done. Yes, they took hot showers afterward , and they weren't in very long.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Algea is not going to hurt them one bit and 5 ppm FC (at 40 ppm cya) would have killed any person to person transmittable diseases (bacteria, viruses). The larger problem when swimming during/before the SLAM process is the inability to see swimmers under the water.
