Thread: I need a refill
    I need a refill
    We are having our pool resurfaced and I'm having a hard time locating the amounts of each item that is needed to properly treat the water upon refilling. I've had both AFO and CPO certifications over the years but it's been quite some time since I've had to use this knowledge. The company that is doing the work is not qualified to do the refill. If anyone could point me to a table of required chemicals per gal. I can take it from there.
    This is a fiberglass over plaster surface, 32,400 gallons, I run a Strantrol, and two Stenners for the orp and ph.
    Any help would be greatly appreciated.
    38,428
    Re: I need a refill
    Welcome to TFP!!!
    Kind of depends on whose advice you are going to follow.
    Our recommended levels (which generally do not match those given by pool stores ... or even the CPO class) can be found in Pool School in this article: pool-school/recommended_levels
    And the recommended pool chemicals can be found in this article: pool-school/recommended_pool_chemicals
    And you can use the poolcalculator.com to determine how much of each is required to reach your desired level.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: I need a refill
    Welcome to tfp, Shortcut
    Is this a residential outdoor pool?
    Re: I need a refill
    Thanks for the fast reply guy's, that's just what I needed. This is the in ground pool at the condo I manage
    38,428
    Re: I need a refill
    That may fall under a "public pool" which may have regulations that would conflict with our recommended levels. Do your homework
