Thread: New to me pool. Need help
    Jun 2013
    SpringHill FL
    415
    Ok so bought a new home with a pool. It uses a cartridge filter. I have no experience with cartridges at all. So i need help figuring out what size filter i have to order a new cartridge.( current cartridge is falling apart tears etc) ok so i know i have a hayward star clear plus but dont know what size. Any tips to figure it out?
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    22,543
    Re: New to me pool. Need help
    Take some measurements of the circumference and height and find a manual and you should be able to figure it out. If you'll post those measurements someone here can most likely help you.
    You may be able to look at the ends of the cartridge and find some part or model numbers.
    Jun 2013
    SpringHill FL
    415
    Thanks bud
    Nathan
    Jun 2013
    SpringHill FL
    415
    The cartridge measures 23" tall by 9" across i believe the circumfrence is 29"
    Nathan
    Jun 2013
    SpringHill FL
    415
    Went to the pool store and measured cartridges they had i believe it is a 120sf cartridge. Any input as to brand of filter that is the best would be appreciated
    Nathan
    Sep 2013
    Fresno, CA
    36
    Unicell are good, and pleatco's are good to. About the same dollar wise, anything name brand, leslies pentair, will be a lot more money. Make sure the opening in the center of the filter is the same size and also look to see if your old filters have a plastic core on the inside. Look into the pleatco's they are touting some new "technology" into the filters, supposed to catch more debris and flow more water. Just maintain the cartridges by cleaning them and you can get good life out of them.
