Results 1 to 9 of 9
Thread: PH doesn't go down?
    PH doesn't go down?
    Hello for a while now my PH has always been at 7.8. I have been adding 14.5 muriatic acid to reduce but I never see any noticible change. I use the tf100 test kit and pool calculator to determine amount to add. For instance in Tue I tested and PH was at 7.8. I added 68ounces of muriatic acid according to pool calculator and when I tested Wednesday morning PH was still 7.8. Do I need a stonger acid? I'm I adding too little?
    Inground kidney plaster pool 30x17 with hayward superstar clear cartridge filter system, sta-rite max-e-pro 2 hp pump.
    22,553
    Re: PH doesn't go down?
    You need to test about an hour after you make the adjustment to make sure it hit the target. If it didn't then dose again until it does.
    What is your TA?
    TA is usually at 90
    38,540
    The amount you added should have lowered it to around 7.2 ... are you sure the pH was not above 8.2 to start? Just keep adding more until you get it to lower to where you want it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do you have a high level of borates (greater than 30 ppm)?
    I'm not adding borates so I have never measured
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you haven't purposefully added borates, then you can assume it is close to 0 ppm. I was asking since borates also buffer ph changes like TA does.
    How are you testing for ph?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I don't see a volume here... 30X17 could be a lot of water. What was the FC when you tested?
    Essential Links:
    Is your TA going down when you add acid?
    Are you adding bicarb to raise your TA?
    New plaster can raise pH.
    Can you post all test results?
    Support the site
