Thread: Goldline AquaRite Cell Life
    Jun 2008
    Near Tampa Florida
    17
    Just curious of what the expected cell life would be for a Goldline AquaRite. I believe I've seen reference to the cell being rated for so many hours and that would be the hours it was actually generating. As I understand it, if I run the unit for 8 hours at a 50% setting, the unit was actually generating for 4 hours.
    Thanks, Mike
    10K Gal IG Plaster, 1 HP Pentair WhisperFlo Pump, 100 sq ft Pentair Clean & Clear Cartridge Filter, AquaRite SWG, Paramount PCC2000 pop-up cleaner, Rheem/Raypak 266 heater, TF-100 Test Kit, SpeedStir
    Oct 2007
    Valrico, FL
    537
    Re: Goldline AquaRite Cell Life
    I saw recently on the Hayward website that they are offering two types of cells: one with a 3 year warranty and another with a one year warranty. If your cell P/N does not have a "W" in it, then I would say it should last at least three years
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Guest
    Quote Originally Posted by dschlic1
    No real difference in the cells, just in the warranty period and how much you pay for the cell. On the average , most cells will last about 5 years but it really depends on the size of your pool vs the output of your cell and also on how well you maintain your water chemistry. (Low CYA and constant high pH are two common factors in early cell failure!)
    Jun 2007
    Poughquag, NY
    217
    My Aquarite is on its 3rd year and still handling the ~30k pool at 35% or so with no problem.
    One other thing to mention is salt level. Keep it towards the high end of the manufacturer's recommendation (that is what Goldline told me on a service call). The cell doesn't have to work as hard, supposedly.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
