Thread: Closing pool - Removing Pump
    Mar 2013
    CT
    353
    I've had a small leak in my pump all Summer and I want to have it looked at and (hopefully) rebuilt over the Winter.
    - Are there any issues with me removing the pump completely after I have Winterized the pool?
    - I have a bottom main drain which will just be air locked during the winter. Will removing the pump affect that at all and possibly let air in - or would I be safe because I assume the shut off valve is before the pump??
    Just want to make sure I can Winterize 100% then pull the pump off...
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    22,553
    Re: Closing pool - Removing Pump
    If the shutoff valve is on the pump suction (which it should be) then it won't affect anything to remove the pump. A lot of people remove both the pump and filter and bring them inside during the winter.
